4x4ord
Jan 27, 2017Explorer III
Crummy fuel economy
I towed a tag trailer 450 km down the highway at 55-60 mph and got 37 liters/100 km. (6.4 mpg). Can you get a Dodge or GM to go through that much fuel?
carringb wrote:
I imagine you must have had some really bad head winds. Or even cross winds. The effective drag from cross winds is almost as bad as head winds!
Yes, that is crummy, and is certainly worse than I AVERAGE with my v10 pulling my monster trailer. But mine has dipped down that far on occasion, when the winds are so strong I can't hold OD.
Tvov wrote:4x4ord wrote:
At 75 mph I would have been pumping diesel but I kinda figured 60 mph was fast enough....The implement I was towing was fitted with 30.5 x 32 combine tires rated for a top speed of 25 mph.
I, as usual, am a little confused. You were towing something at more than twice the speed that its' tires were rated for? Why?
4x4ord wrote:
With a 5.9 Cummins....wow you must have had your foot into to it pretty good. Were you able to maintain 60 mph?
4x4ord wrote:Cummins12V98 wrote:
Towing with 11 RAM Dually combined weight 29k into 40mph head winds at 75mph I was 6mpg.
Did you ever pull your '07 MS with your 2015 Ram? I'm curious as to how much more power it takes to pull a 29000 lb RV vs a 20k lb unit?
