I have to remove the wheel simulators to reach the inside dually valve stems. Is there a way to check the inflation and get air to these tires without the hassle of removing the simulators?
See if there is a long valve stem that can be used for your setup. Check dually kits etc. My steel valves now extend out so that they can be easily reached.
I do not recommend any type of valve extension.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
