rdhetrick
Feb 05, 2020Explorer
Without knowing the coach UVW, it's not possible to give accurate numbers. However, all those ratings are independent - meaning you could max out on one, and the others would be ok. The 10k towing capacity is just the rating of the hitch
For example, if the coach UVW was 18k, you could put 2k of weight in the coach and you'd be able to pull a 10k trailer/toad. In this case, you'd be at the limit of the GCWR and the hitch rating, and you would be under the GVWR.
If the coach UVW was 24k, you could still put 2k of weight in the coach to get to the GVWR, but you would be limited to a 4k trailer/toad because of the GVWR even though the hitch itself is rated for more.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
