- wbwoodExplorer
Dougjpr wrote:
Thanks for replies.
Reason for not looking at towing 4 down is that I may use different vehicles behind coach and don't want to be buying base plates.
Doug
Wise advice - j-dExplorer IIFront Wheel Drive on a Dolly offers you a lot of choices. As a group, FWD has the highest % chance of being towable on a dolly. Just watch out for the exceptions.
If you're considering towing something like a minivan, be sure the dolly can accommodate its width.
I've been told that a dolly is easier on the vehicle being transported than if it were towed four down, flat, FROG, or whatever not using a dolly's called.
Some dollies are better than others, of course.
Get one with its own brakes. - DougjprExplorerThanks for replies.
Was referring to a front wheel drive vehicle
Vehicle being towed on a dolly
Of course none of this is an issue at this time as we have not purchased a coach yet
Just tying to research things at this point
Thanks again
Doug - BumpyroadExplorerIf you haven't got the toad yet, buy one that can be towed 4 down as is. check the owner's manual to confirm towability, use other sources as a starting point.
bumpy - mowermechExplorer"Some here call Dolly Towing TOAD (Two On A Dolly) and Tow Bar Towing FROG (Four Rolling On Ground)."
OK, if you say so. What I have read is that "TOAD" is a variation of "TOWED". The definition of "FROG", however, is correct, although it is rarely used. Most of the time it is referred to as simply "FOUR DOWN" towing. "On a dolly", of course, means exactly that, 2 wheels on a dolly and 2 on the ground.
It is, however, quite true that generalizations are often false. There is almost always an exception or two!
I have heard of a front wheel drive vehicle (sorry, don't remember which one) that apparently had speed sensors on the rear wheels, and so could not be dolly towed because it confused the computer.
I have never seen an Owners Manual for a four wheel drive or all wheel drive vehicle that states dolly towing is OK. Of course, I haven't read ALL of them.
Generally speaking the ONLY four wheel drive (4X4) vehicles that can be towed four down are those which have a NEUTRAL position in the transfer case. However, that is not always true. There is at least one transfer case in older vehicles that must be modified by welding vanes on a gear for splash lubrication before four down towing is attempted. That transfer case has not been in common use since the late 1970s/early 1980s.
ANY vehicle, up to the size/weight limits of the trailer, can be towed on a trailer, IF the ground clearance will allow it to be driven onto the trailer.
ALWAYS read and follow the instructions in the Owners Manual!
Especially if your vehicle is under a manufacturer's warranty.
Some folks say that certain vehicles are towable despite what the manufacturer says in the book. "Why, I have towed my Flashbang Sport for xx thousands of miles, with no trouble at all!" That does not mean that you will be that lucky with YOUR "Flashbang Sport"!
Good luck. - j-dExplorer II
dons2346 wrote:
Are you talking about a Four Wheel Drive? If so, the answer is no.
Are you talking about a Front Wheel Drive? Then the answer is yes
Please don't take "a" to mean "EVERY". Not at all sure Every would be correct. Check the Owner's Manual, EVERY time. You don't want to be one of those rare exceptions.
MOST Front Wheel Drive on Dolly... Yes
But All Wheel Drive... No
MOST Four Wheel Drive... These seem to be "all or nothing." Many, maybe most, are OK with all four down (tow bar) or all four up (trailer) but rarely OK with two up and two down (dolly).
OP said "Dolly" but second reply sounds like Tow Bar. Be careful! Transmissions are expensive and trips canceled/delayed are frustrating.
Second response is about - jerseyjimExplorerI "toad" a 1996 Ford Contour FWD with a STICK SHIFT....4 years with no problems. I also "toad" a 2007 Chevy HHR AUTOMATIC for 7 years with no problems.
Currently "toad" a 2011 Ford Ranger Automatic 4WD with no problems.
Just FWIW. - dons2346ExplorerAre you talking about a Four Wheel Drive? If so, the answer is no.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 09, 2026
