NEOK
May 22, 2017Explorer
We replaced ours with a Delta residential faucet last year. Just make sure the new one will fit the holes where you removed the existing one. Also, if you want to go with a pull out residential faucet make sure there is adequate room und the counter and sink to hold the hose for the faucet. THe hot water tank, water supply lines and drain pipes under our sink did not leae enough room for a faucet with a pull out hose.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
