carringb
Jul 28, 2015Explorer
Are you sure it was in accessory and not in run? This will trigger all the brake system lights shown because of the wheel speed difference. Did you disconnect the battery for 10 minutes to see if it clears? If not, a sensor wire fault is very likely.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Mar 13, 2017
