MFL
Mar 12, 2021Nomad II
dedmiston wrote:SpeakEasy wrote:
I'm not really sure what a micron is. Is it a two-dimensional measurement? If so, then you're correct about 0.5 being 10 times better (smaller) than 5. But if a micron is a one-dimensional measurement, an opening has both length and width. So, assuming a square space, if the length of the space is 0.5 microns compared to a length of 5 microns, the difference in the 2-dimensional size of the opening is actually 100 times bigger with a 5 micron space than a 0.5 micron space.
It's more complicated than that.
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge.
Well now...put this way, it is easy to understand!
Jerry
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
