SpeakEasy's avatar
SpeakEasy
Water Filter Cartridge Replacement
My TT came with a built-in, in-line WaterPur water filter. Apparently WaterPur is a brand connected with Forest River products? It's time to get a replacement cartridge. The ones bearing the "WaterPur" label are, of course, overpriced. There are off-brand alternatives being marketed at a lower price. One is Neo-Pure (clever name). Then there's Sprio-Pure. There are probably others. I don't doubt that the off-brand ones will fit, but do they contain comparable filtering elements? Does anyone have any experience with any off-brand replacement filters for these?
TIA
-Speak
  • midnightsadie wrote:
    charcoal filters help with taste and filter also. under $10.
    If you want a filter that is QUALITY made here in the USA instead of China I highly suggest this unit. Been using this one for several years. Change it every 3 month full time use.
    Pentek - 455903-43 FloPlus-10 Carbon Block Filter Cartridge, 9-3/4" x 2-7/8", 0.5 Micron $16.00 AMAZON Prime.
  • I got one from HD or Menards. it fits the canister perfect. however when I had my TT I did the same thing and the pump wasn't strong enough to overcome the filter. on our current MH the pump is more than strong enough.
  • I double filter. One inline filter at the hose bibb and a charcoal filter in the cannister inside the trailer.
  • Visit your nearest big box home supply (Lowes, Home Depot, etc) or hardware and pick a cartridge of the same size for the type of filtering you are most interested in doing.
