Below is the setup I installed under the kitchen sink at the back wall. Doesn't really interfere with the use of the cabinet. First filter is a 63 micron sediment filter (washable), 2nd is a 5 micron string-wound sediment filter, 3rd is a 1 micron Doulton ceramic filter (can be cleaned repeatedly) and last is a 0.2 micron Crystal Quest "ultrafiltration" (UF) filter. I got the 10" housings cheap at a plumbing wholesaler and the cartridges off the internet. The ceramic cartridge supplies the kitchen faucet only and the UF cartridge supplies an RO type faucet for drinking water only. The last season has been the worst so far for visual buildup on the filters.
Water filtration and cartridge selection can get quite complex and what you want will depend on what you want to accomplish. Water filtration for RVs has it's own unique challenges because you can travel all over the place and not know what's in the water. Even water from gov't regulated municipal systems can be an issue. Some unknown sources like lakes and wells can be an issue as the water can be untreated and unregulated.
I recommend against carbon filters because they remove chlorine from your piping system, leaving it unprotected against biological "stuff". Below is a photo of our city water inlet filter screen. This is a biomass blob caused by the absence of chlorine in a CG water system and their failure to flush their lines after sitting unused over a winter and the dissipation of chlorine levels. Wanna ingest this kinda stuff? Not me... That was about when I decided to install some good filtration.
Cryptosporidium and Giardia parasites are chlorine resistant and if you want to remove them, you need a filter with a small enough micron rating - 1 micron or less and should be
absolute rated, not nominal.
If you are using a sediment filter only, do you know how it's made? If a paper type, bacteria love to grow in them. A string-wound type will prevent that. Water can have a range of contaminants like heavy metals, chemicals, bacteria, viruses, parasites, pesticides, etc. Filters can remove some of these things but not all.
Note that filters with KDF or silver in them do not prevent pathogens from flowing through them, it's in them to prevent them from growing inside. You should look for NSF rated filters otherwise they can have exaggerated claims, or no specs at all and you won't know how they really perform. Multiple filters can cause pressure/flow drop. Inline exterior filters can have high micron ratings. Read specs carefully and don't just grab the blue one or the cheapest on the shelf.
