machunt
May 28, 2018Explorer
water filters
Whats everyone use for fresh water filtration? we use the standard wal malt single inline filter, seems to work ok, but has to be something better. for outdoor use.
Cummins12V98 wrote:
I have plenty of flow even with my WATTS regulator set to 60psi. Something is not right with your setup.
pnichols wrote:
1. Dump 6 oz. of chlorine (for 40 gallons) into the refill hose before I screw it onto the hookup faucet so that the fresh water tank and whole system get sanitized with this chlorine every time I refill and eventually use - 40 gallons of water out of the fresh water tank.
Lynnmor wrote:
That is way too much bleach, 2-1/2 teaspoons for 40 gallons would be the EPA recommended amount.
My Itasca (Winnebago) motorhome's owners manual recommends about 6 oz. of chlorine to disinfect it's 45 gallons (includes the 6 gal. hot water heater) of onboard fresh water.
This chart recommends about the same: https://www.purewaterproducts.com/articles/chlorine-dosage
So ... at the beginning of each trip I fill the fresh water tank including about 5-6 oz. of chlorine.
