BB_TX's avatar
BB_TX
Nomad
Jan 15, 2019
Water heater, anode rod, electrolysis, and teflon tape
It is often stated on RV forums that you should not use teflon tape on the anode rod threads as it could interfere with the electrical contact. Being fairly knowledgeable in electric (retired EE) and limited knowledge of electrolysis, something just did not sound right. And my little engineering brain can't live like that. And finding nothing definitive by googling, I went directly to the source. I e-mailed Suburban with my question, "Does the anode rod threads have to make electrical contact with the water heater threads for the anode rod electrolysis to work properly?"
I got a quick reply from an assistant service manager at Suburban as follows;
"The answer is No. The metal threads do not need to make contact with each other. Electrolysis is the chemical reaction that takes place inside the tank and has nothing to do with the threads. I've attached some Suburban water heater videos to this email that I believe you'll find very interesting."
And here is the video they attached, actually using the tape. So those who use teflon tape can rest easy.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: May 03, 2023
