Vulcaneer wrote:
jsr21 wrote:
If you only have one valve to bypass your water heater then it is
the system that uses a check valve in the top fitting in the water tank to prevent afreeze from entering the water tank. I had to change one today....sounds like yours needs changing to.
This gets my vote. Remove the check valve from the top (inlet) fitting. If you can blow air thru both ends, it needs cleaning or replacing. They like to attract calcium deposits...and that keeps them from closing completely.
This could be a possibility but the trailer was built in April 2013. Could deposits accumulate that quickly? I've taken maybe 11 trips in the rig so far. If so then I need to find a better solution so I don't have to replace the check valve every year.
