dons2346
Jul 19, 2013Explorer
cross country wrote:
there is a sensor in the flame which must create the correct (voltage I think) to keep the gas valve open.......
The part you are referring to is the ignitor. It will spark igniting the gas. It, along with the flame then acts like a resistor in the system which then keeps the gas on.
The gap has to be to specs, all surfaces of the mounting need to be corrosion free and making good contact. Another serious area is where the brass gas nozzle meets up with the part that you adjust the gas/air mixture with. It is a slip fit and crud/rust can get between the brass and aluminum air mixer. It is part of the safety circuit and a few milli volts is present so if the slip joint isn't clean, it won't work
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
