RamblinMurph
Jan 10, 2014Explorer
Water heater out for repairs - anything else to do?
Pulled my 10 gallon water heater today to have a hole welded. I had a fitting crack which shorted the temp control and made a hole in the tank. I had the hole welded today and the repair guys suggested replacing the element and using a thermostat from a house water heater to replace the damaged sensor. After removing the tank, I found, when draining, that there was a good bit of white particulate in the tank. We removed the element which is covered with similar white "stuff". I plan on getting it back in tomorrow and wanted advice on their ideas and anything else I might should do to get this heater ready for 15 or more years of operation.
Any advise would be appreciated!
