Can't buy just a tank as replacement for Suburban ------ not sold. Steel tank that is glass-lined therefore only components or Compete units are sold.
Suburban 10 gal......replace with Suburban 10 gallon
Otherwise you have to do lots of modifications to opening in side of rv
Tankless......
Can be installed and with the right tweaking can be made to function correctly.
Biggest issues are water supply temp AND consistent pressure/flow
CG water supply system fluctuate more then residential settings due to constant change in demand so pressure/flows are constantly changing.
Good high flow adjustable water pressure regulator and removal of all resistors in RV plumbing system will help
Tankless can be done
BUT direct replacement of RV WH with an RV WH (Brand for Brand/Size for Size) is easiest
