mikebreeze
Sep 11, 2013Explorer
Need Hot Water Heater Advice
Last weekend I went to turn on my hot water heater and had some issues. After a few minutes I saw and smelled a smoke and a burning smell coming out of the outside vent on my rig. Since this smoke was coming out right above the propane flame I immediately shut off the hot water heater. I then looked at the hot water heater itself and saw water around the base of it and also a small leak at the bottom of the RV. So I think that I either had a leak in the plumbing pre-water heater that caused insufficient water levels in the heater, which caused the element to burn. Or I had a leak in the water heater itself, which caused the same result. So I believe that I will be needing a new hot water heater.
So I am now deciding on replacing my conventional 6 gallon hot water heater with the same device or going with a tank-less hot water heater. Pros that I have read for the tank-less include instant, unlimited hot water and less weight for the device itself. Cons include more expensive price, the faster the flow, the cooler the water and excessive start up spike in current. Has anyone here replaced their hot water heater and which route did you go? Thanks in advance.
