Old-Biscuit
May 13, 2019Explorer III
Leaking when running A/C Unit or right after you shut it down....evap coil drip tray overflowing due to clogged drain lines
Leaking when raining.........loose A/C Unit and roof rain water is leaking past roof gasket
The 4 hold down bolts need to be 'snugged' up (snugged up means 40 INCH LBS....in other words just slight tightening past finger tight)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
