turbojimmy
May 13, 2019Explorer
If you had been running the a/c I'd guess a clogged drain tube at the catch pan. But if you haven't been running the a/c, the leak is probably elsewhere and finding its way to the opening for the a/c. You can try snugging down the bolts that hold the a/c to the roof but even if they're loose the weight of the a/c usually keeps the gasket compressed enough to prevent leaks.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
