mgirardo's avatar
mgirardo
Water leak through Air Conditioner...
This morning I discovered a "leak". A small puddle in the kitchen under the A/C unit. It rained most of the day yesterday and it's been raining most of the morning. I went on the roof and could not find a tear or puncture on the roof anywhere around the A/C unit. I was just on the roof the other day inspecting it and found no issues the either. We have had a lot of rain the last few weeks and have not found any water inside, we camp seasonally and have been in the unit since the end of April. The puddle is in the path of the bunkhouse and if we had a puddle before it would have been found with the kids going back and forth to the bunk house.
I pulled the cover off the A/C unit inside the camper. The wood all around the opening is dry and there is no obvious signs on the wood that water has leaked in the past. The water appears to be coming in through the opening where the fan is (circled in the photo below). All up in that area was wet. The foam divider is dry.
Since it was raining, I did not pull the roof top shroud to take a look. I am going to cover it for the time being as it is supposed to rain for the next 24 hours or so and we have to go out of town for a few days.
Without seeing photos of the top side of the unit, does anyone have any ideas where the water could be coming in? It hasn't been warm enough to run the A/C, so I don't know if it is functioning properly or not.
One thing I did notice after I discovered the puddle, it really started to drip when the furnace kicked on and it wasn't raining very hard. Right now it is a steady rain and there is no dripping. Could it just be condensation build up? It was chilly last night, mid 40s and the heat is set to 72. There is no condensation on the windows.
Thanks in advanced,
-Michael
  • Either a plugged condensation drain tube which you access by removing outside cover or the mounting bolts inside need to be tightened slightly.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
