jkm1950's avatar
jkm1950
water line leaking
I have a 2004 Winnebago Adventurer. I forgot to connect the pressure regulator to the water inlet. I found out later that the RV park had 100 psi. Now I have water dripping from both side of the coach. I have tighten all the connection I can reach. How do I get to all the line inside the floor. Any ideas.........
Jim
  • There's no trick here, you simply have to uncover pipes until you find the leaker. You may have to cut some holes, preferably in cabinets and such, to find the problem spots. Or, come up from underneath.
  • It sounds to me that you may have a burst water line rather than just a loose fitting. Perhaps you should start looking for a damaged water pipe or hose rather than tightening fittings.
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Apr 01, 2026
