crouseman41's avatar
crouseman41
Water Pressure Regulator Failure
Rude awakening this morning - rug in front of toilet was water-soaked. Checked water pressure regulator, Watts #H560, and it showed 90 lbs. pressure. The regulator that failed is about three years old. We previously had used an in-line regulator, but decided to upgrade to the Watts. Just never realized that failure of the Watts regulator would allow full line pressure through to the motorhome. The failure happened sometime between 1 a.m. and 8 a.m. and the toilet valve was the only place there was a leak. Found a new in-line regulator and installed it - disaster averted and problem solved.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
