This is not a huge problem - just a bit annoying, and I've never noticed it before. I'm connected to campground water and the pressure is a little high. I'm using a pressure regulator at the spigot. T...
If the regulator is on the spigot end, it is possible that it is the regulator. The larger diameter hose acts as an accumulator tank. Once the pressure drops the small hole in the regulator restricts the flow. I would opt for a better regulator like the Valterra A01-1117VP or a Watts Valterra
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
