allenmExplorerJan 16, 2016Water PressureThis is not a huge problem - just a bit annoying, and I've never noticed it before. I'm connected to campground water and the pressure is a little high. I'm using a pressure regulator at the spigot. T...Show More
Old-BiscuitExplorer IIIJan 16, 2016Try removing that filter and see how the flow is.IF same issue then try a different hose. (borrow a neighbors for test)With no filter and a different hose......same issue then its the regulator
About RV Tips & TricksLooking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
Related ContentWater pump?Why no hot water?Water Pressure RegulatorLow Water PressureWater pressure regulator
