georgelesley's avatar
georgelesley
Water pump adjustment
We have a Shurflo 4008 bypass type pump that cycles on and off constantly no matter the flow rate demanded. The manual says the hi pressure setting might be too low. There is an adjustment on the pressure head.
Anyone ever do this, if so how sensitive is the adjustment, is the pump running to set it?
  • I would check for a leak first, if it was working ok until this problem started...
  • Not familiar with that particular water pump but in general a water pump that turns on when the faucets are turned off indicates that you have a small water leak in your plumbing ... I would rule that out first as water pumps are inexpensive .. replacing water logged wood is often very expensive. If you have outside shower .. suggest you start your investigation their.
  • Are you sure the pump needs an adjustment? You may have a small leak or the check valve is not seating properly. It will not have to leak very much to allow the pressure to bleed off.
  • Don't know what your manual says but this is from the website
    NOTE: By-pass adjustment should only
    be performed by a professional technician
    with proper gauges and equipment.
    The by-pass is a spring loaded diaphragm
    that opens up allowing water
    from the discharge side back to the inlet
    side. The by-pass is set to begin opening
    at about 40 psi and creating full by-pass
    at about 62 psi (lower pressure pumps
    will vary depending on the by-pass and
    pressure shut-off settings). The pressure
    switch on the pump is set to shut
    off at 55 psi. If the switch or by-pass
    are adjusted too much, the by-pass and
    switch shut-off can overlap and THE
    PUMP WILL NOT SHUT OFF. Screwing the switch screw in clockwise will
    raise the shut-off pressure. Unscrewing
    the switch screw counterclockwise
    will lower the pump shut-off pressure.
    Screwing the by-pass screw in will raise
    the pressure at which the by-pass starts
    and raise the full by-pass pressure.
    Unscrewing the by-pass screw counterclockwise
    will lower the pressure at
    which by-pass starts and lower the full
    by-pass pressure.
    WARNING: If full by-pass is reached
    before the shut-off setting, the pump
    will not shut off. Full by-pass pressure
    setting should be at least 10 psi higher
    than pump shut off pressure
    http://shurflo.com/images/files/RV_Product_Manuals/Fresh-Water-Pumps/911-1008.pdf
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 08, 2025
