mlts22 wrote:
I think it is time for a new pump. To keep it from doing late night "burrup" noises, Shurflo sells an accumulator tank, and I'd recommend replacing the pump and adding the tank. That way, when pressure varies, the pump will not need to short cycle, as it will run to pressurize the lines and the accumulator tank.
Looking at the accumulator tank, is there any advantage to the Shurflo tank vs Watts or some other larger tank that I've seen on other threads and seems to be about the same price as Shurflo? 1-2 gallon vs 0.7 liter listed on the Shurflo. More capacity seems like it would be better as long as I have room for the tank near the pump.
Thoughts?
