SoundGuy wrote:
SoundGuy wrote:
But hey, if you choose to not believe the video proof I provided then go ahead and ignore this solution which absolutely does solve the problem. :R
Sam Spade wrote:
What you have demonstrated proves something alright......but NOT the problem at hand.....since it does NOT really reduce the vibrations AT THE PUMP. IT only proves that sound waves diminish with distance. This is true regardless of the transmission medium.
IF....the offending noise is transmitted directly from the pump body to the frame of the RV, you can put a hose a mile long on the outlet and it won't make any difference.
You're being argumentative simply for the sake of it and everyone here knows it. :S Of course, isolating the pump helps BUT that alone is not the solution ... adding a long length of soft potable hose to the pump output is - noise will be dramatically reduced, to the point where you'd be hard pressed to hear the pump running at all.
OR - stick your head in the sand, continue to offer silly arguments to the contrary, and continue to listen to that pump of yours rattle away. Your choice - I could care less what you choose. :R
What you are seeing is SOP for him. Alias easy rider/Vulcan rider. Just consider it a form of entertainment and assist the OP the best you can. :W
