ugeesta wrote:
My water pump is sucking air and I think Iknow the problem area.
Last year I installed a winterize valve and had trouble connecting the water hose to the extended end of the water pimp intake. Like a good man, I pulled on the hose and forced fit the connection. Now e pump is sucking air :S
After filling the water tank to the overfill point, I start the pump and it still gets air.
If I apply pressure to the water intake and filter, the pump starts to operate normally and stops when the pressure is right.
I don't believe there is a crack in the plastics but I think the two piece elbow is stretched out causing e air leak. Can I Jerry rig this elbow or is it better to just get a new one? If a new one is in order,does Walmart carry them?
Thanks.
You found the source of your problem - the pump is sucking air from somewhere. When you apply pressure the air trapped in the lines somewhere is displaced and the pump operates normally. It's a water pump - not an air pump.
You could,if possible,apply air pressure to the lines and fittings and see if you can hear or feel air leaking. You can also mix up a soapy solution and spray it on the lines and fittings to detect an air leak. You probably cracked a plastic fitting when you pulled on it.
I would suggest you locate the source of the air leak and replace with a new piece without using excessive force.
Any RV supply house or Lowes etc. should have what you need. Try to replace any plastic part with a metal part if possible.
