jamesk1's avatar
jamesk1
Water pump wont shut off
The waterpump in my daughters pulltype camper wont shut down. It seems to build pressure then quites down and there is pressure at all lines but the kitchen sink cold water is just a trickle. Traced all the lines and there isn't a leak. Should say it shuts down a bit when the pressure is built up but never shuts off. I could see where it might have a kink in the line or something blocking it as a reason why it is just a trickle but cant figure out why the pump will not shut off. Ive went over every inch of that cold water line and no leaks. Maybe the pump is bad or any other reasons for it? All other lines seem to have plenty of water pressure so thinking something got in the water line to the sink but shouldn't the pump shut down anyway? Any ideas? Thanks, JIm
  • If it sucks up a piece of debris and it gets stuck in the pump head it will do as you describe, especially if it had been fine before and failed suddenly. I've had it happen 3 times - twice on brand new TT's that probably had plastic junk in the tank. To fix, take the pump head apart and rinse all the parts with water. Re-assemble and it will probably be fine.
    Good luck,
    Scott
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
