LOFAT36
May 22, 2019Explorer
Water pump
After 6 months in Arizona, arrived home end of March in Canada. Drained and winterized after getting home. Today I filled the fresh water tank and turned on the pump to fill the hot water tank. Now th...
rockhillmanor wrote:. 2011 Rockwood TT. Fill cap is on and I never touched any valves when I got home. Is there a reset on the pump ?LOFAT36 wrote:It means something is open somewhere. Would help to know what type of RV as water inlets differ.
After 6 months in Arizona, arrived home end of March in Canada. Drained and winterized after getting home. Today I filled the fresh water tank and turned on the pump to fill the hot water tank. Now the pump won’t shut off. I left it off for a hour so but when I turn it back on it still runs. No leaks anywhere. Any ideas ?
Check your water inlet fill cap on tight and check the screen inside. Check valves can get worn out or just pushed out of position. Push it with your finger to reseat and try again.
