After 6 months in Arizona, arrived home end of March in Canada. Drained and winterized after getting home. Today I filled the fresh water tank and turned on the pump to fill the hot water tank. Now th...
You said you "filled the tank". Do you have a tank fill valve by your city water hose inlet (not talking about the gravity fill port for the fresh water tank, but where you connect the hose for city water use in the RV)? If that fill valve is left in the fill position (instead of "city water pressure to the coach" position), the pump will just be circulating water back to the tank nonstop.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
