- Ro_n_JoeExplorer IIAgree with filter prior to softner and I like having the pressure regulator plumbed in the wet bay. One less thing to setup upon arrival.
- ncrowleyExplorer IIAs others have stated, you want the filter before the water softener. We have a sediment filter and a charcoal filter before the softener.
- eHoeflerExplorer IIThe water softener is a 10 micron filter, when back flushed, all cought debris is flushed out. In my house I run a 20 micron before, and a 5 micron charcoal after. In the fifth wheel I don't use a filter before, but I do use a 5 micron after. I wind up regenerating my softener every 7-10 days, and back flush it every other time.
- Old-BiscuitExplorer III
bobsallyh wrote:
I run the filter before the softener. You really don't want "bits and pieces" going in your softener.
YEP^^^^^^
Pressure regulator at spigot/hose bibb......in-line filter(s)....softener....then RV 'city water' inlet
OR...after softener just fill the RV Fresh water tank, secure the CG supply and run off fresh water tank/pump - bobsallyhExplorer III run the filter before the softener. You really don't want "bits and pieces" going in your softener.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
