acritzer's avatar
acritzer
Explorer II
May 24, 2017
Water tracking in from slideout?
Our camper is a bit low on the door side, opposite of our slideout. Today, after very hard rain I noticed some water, which appears to have crept in past the rubber seals very near the slideout track.
Is this "normal" or expected? And mostly a symptom of the trailer being angled poorly?
We have previously camped through a much longer and harder rain with no issues.
It's a 2015 Coachmen Apex.
To me, the rubber on the sides looks good, and on the top, but the pieces around the track looks poorly designed. Not broken, but not a great seal either.
  • wildtoad wrote:
    Slides are a result of a major hole in the side of the RV. The top, bottom and side seals do a decent yet not perfect job of preventing water intrusion. One should not been surprised with a small amount of seepage during a storm. Do what you can to keep the seals clean and lubricated, and trash off the top of the slide that might cause a poor seal.
    Sounds like what I was thinking too. Hard to explain over text, but the bottom part of the seal just doesn't look especially well thought out. I realize the track not being flush with the wall makes it's a challenge, but there's a goofy little rubber piece that doesn't fit in here particularly well. I suspect that's where it was sneaking in.
  • Slides are a result of a major hole in the side of the RV. The top, bottom and side seals do a decent yet not perfect job of preventing water intrusion. One should not been surprised with a small amount of seepage during a storm. Do what you can to keep the seals clean and lubricated, and trash off the top of the slide that might cause a poor seal.
  • spud1957 wrote:
    Trailer needs to be level for seals and drains to work properly around the slide.
    Experience speaking.
    Or even better, a little low on the slideout side?
  • Trailer needs to be level for seals and drains to work properly around the slide.
  • No water should creep in at all. Check seals first. Were you level?
    Why not use some lynx lock levelers and make your trailer a tad higher on the opposide side which would solve your problem ?
    Jack L
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
