Do any of you use a water transfer pump to refill your trailer from water you brought when you go dry while boondocking? I saw a guy using a 5 gallon container and a large funnel. Seems there should...
I do as Dieseltruckdriver. Before I got the extra sureflo I used an inexpensive bilge pump rigged up with a lamp cord and clamps for power and a short piece of male ended hose clamped to the discharge. I would throw it into a 30 gallon plastic tub and pump away. worked great.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
