Do any of you use a water transfer pump to refill your trailer from water you brought when you go dry while boondocking? I saw a guy using a 5 gallon container and a large funnel. Seems there should...
Using an older but still working RV water pump is best, but here's another cheap idea.
If you're carrying a drill with you, go to any hdwr store and they'll sell a cheap pump that you power with your drill motor. They're about $11. The pump will have hose fittings on both sides of it. You can buy several feet of cheap clear plastic tubing to fit over the hose fitting. I use this set-up for pumping my RV antifreeze for winterizing.
Bill
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
