Do any of you use a water transfer pump to refill your trailer from water you brought when you go dry while boondocking? I saw a guy using a 5 gallon container and a large funnel. Seems there should...
I presurize my 25 gallon water transfer tank with my 12 volt air compressor. Already had the compressor. Just had to add a tire valve stem to the top of the tank and a hose spiggot to the bottom. Now the compressor does double duty.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
