Do any of you use a water transfer pump to refill your trailer from water you brought when you go dry while boondocking? I saw a guy using a 5 gallon container and a large funnel. Seems there should...
I flip the water control valve from normal/city to sanitize tank and just let the on-board pump draw water into the tank with a small length of fresh water hose. I can draw water from any vessel that holds water, even little 16 oz water bottles if absolutely necessary.
-Michael
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
