Do any of you use a water transfer pump to refill your trailer from water you brought when you go dry while boondocking? I saw a guy using a 5 gallon container and a large funnel. Seems there should...
I have a 5 gal jug, and funnel - and I have a 40 gal pillow tank and a pump.
If I just need a little more water for a day or so - the 5 gal. If needing more - the 40 gal tank. (FW tank on TT - 42gal).
If water fill is in the CG, I'll fill the pillow tank with it on top of the cab of the truck and use gravity to fill the TT tank. If water fill is outside the CG (or poor water quality in the CG) - the pillow tank goes in the bed of the truck, and use the pump to fill the TT.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
