Wheeldog's avatar
Wheeldog
Wave 6 heater
Bought a new Olympian Wave 6 heater for my 9.5 ft S&S Camper. It isn’t doing very well at all.
It was about 45 outside and was 48 in the camper. It took 4 hours to bring the camper temp to 68 on the high setting. This is the second time I have experimented with the heater. Took about the same amount of time when I did it before. Once it hit 68 inside I turned it to medium. It would stay at 68 but not get any warmer.
In my latest 3rd test I had the wave 6 on high for 2 days. The temp got down to 30 last night and it was 55 in the camper this morning.
I am/was planning to use this to heat my camper this winter……..BUT……I’m thing if it’s doing such a poor job when the temps are in the 30's & 40’s whats going to happen when it gets down to zero?
I am at a low elevation, about 400 ft.
I am trying to figure out if it’s a bad heater, maybe I am doing something wrong, or it’s just the way they work??? Any ideas would be appreciated.
  • 6000 btu's = about 1700 watts. In the worst of the winter I need 7000 watts (peak) or about 24000 btu's
    The wave simply isn't up to the task. And lots of heat goes "out the window" if you have a window and a roof vent open as is required.
    Add insulation every where you can.
  • The problem with a small heater trying heat a cold camper is that every part of the camper and everything in the camper takes a lot of heat to warm up before the air can get where you want it. Once the camper is warm, results will probably be more acceptable.
  • At a maximum output of only 6000 btu, it is unlikely that this heater will keep your trailer toasty once winter really sets in. The average RV furnace puts out a minimum of 35,000 btu.
  • I've been wanting one of those. Never used one. But plan was to point it at something big and then use a fan to blow that heat off the object and into the air.
Looking for advice before your next adventure? Look no further.25,151 PostsLatest Activity: Jul 25, 2025
