- old_guyExploreruse something else. WD40 attracts dirt too much
- BB_TXNomadI use a PTFE dry lube spray from Home Depot.
- JEBarExploreryou'd be better served to use a dry lube that will not hold dirt and grit .... WD40 makes a dry silicon spray that works pretty well
Jim - downtheroadExplorerWhen my can of WD40 ran out I didn't replace it.
Most often use Silicone spray or white Lithium grease. - camperpaulExplorerNo.
- Turbo_Diesel_DuExplorerNot a lubricant, but is a water displacing spray as the name implies. Lots of folks misinterpret the WD-40 as a lubricant. Should try silicone or a real light lube oil. Will work much better. JMHO
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 20, 2025
