Only_True_Mosno's avatar
Jun 21, 2014
WD 40 on Glide outs, Jacks, & Landing Gear ?
Is it okay to use WD40 to lubricate things? Thoughts ?
  • you'd be better served to use a dry lube that will not hold dirt and grit .... WD40 makes a dry silicon spray that works pretty well
    Jim
  • When my can of WD40 ran out I didn't replace it.
    Most often use Silicone spray or white Lithium grease.
  • Not a lubricant, but is a water displacing spray as the name implies. Lots of folks misinterpret the WD-40 as a lubricant. Should try silicone or a real light lube oil. Will work much better. JMHO
Looking for advice before your next adventure? Look no further.25,143 PostsLatest Activity: Jun 23, 2025
