LIKE2BUILD
May 18, 2016Explorer
Need-A-Vacation wrote:
If you have a trunion bar system make sure the lug will not hit the trailer frame in a tight turn! It depends more so on if you have a top mounted coupler or bottom mounted coupler. Top mounted couplers you usually need to adjust the bars down a little more for clearance of the trailer frame.
Good point. I've found that trunion bar systems usually fit best on bottom mounted couplers and round bars work best with top mounted couplers. That tends to eliminate issues with clearance of the trailer frame rails and provides the bar angles and ground clearance.
KJ
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
