drsteve
Jan 15, 2018Explorer
You will feel passing trucks tug at you even with a perfect setup. As long as no sway is induced, it's all good.
Try to get the trailer to set level or slightly nose down.
It sounds like your tongue is light. The WD hitch will not compensate for that.
You are correct that the head angle seems to be too upright.
You shouldn't be pulling faster than 65 anyway, but the trailer should not sway, even if you do.
A trip to the scales may be in order to eliminate the guesswork.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
