Drew_A_'s avatar
Drew_A_
WD Hitch or not?
Greetings,
I am towing a 26' 7000 pound gross travel trailer with my 2018 Ram 3500 CC SB truck. Do I need a weight distributing hitch with this combo?
The Ram manual states the max tongue weight for 2500/3500 trucks is 1800 pounds but does not say if that is with/without WD. There is no mention of WD in the manual except for the section about how to adjust spring bar tension.
Thoughts?
-Drew
  • There should be a ratings label on the reciever that will have a 'dead weight rating' and a 'WD weight rating'
    Found this image below on rv.net
    Dead weight or weight carrying = no WD system
  • BurbMan wrote:
    The easy answer is....it depends. Assuming you don't pack the truck with heavy stuff, the tongue weight of the trailer by itself is probably not enough to make the truck sag. WD hitches also provide some level of sway control, so there's benefit there even if you don't need it to level the rig.
    If you're towing without a WD hitch now and not having any issues, then there's your answer. If you are having issues, then there's your other answer....
    Thanks for the input. I have only towed it once: 3 hours home from the dealer. The trailer was completely empty as was the truck. With this trailer having a rear kitchen, I was concerned it might sway due to low tongue weight.
    On the trip home, I used a standard WD hitch with 1200 pound bars and no sway control. The tow was great with no sway at all.
  • The easy answer is....it depends. Assuming you don't pack the truck with heavy stuff, the tongue weight of the trailer by itself is probably not enough to make the truck sag. WD hitches also provide some level of sway control, so there's benefit there even if you don't need it to level the rig.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 22, 2025
