Kfd518's avatar
Kfd518
WD hitch setup with air bags
Alright, 1999 ram 1500 RWD new style husky center line WDH. had quite a bit of squat in the rear end before and had to use 8-1200#bars to get enough weight transferred back to the front of my pickup. I knew from the towing that was done before I got it (without weight distribution) that the rear suspension was quite tired. Anyways I added 5k bags this weekend , went back down to 600-800 #bars and re adjusted everything the following is what I ended up with, I am wondering why one side would transfer more weight back to the front axle as it is doing and if anyone thinks I should drop the spring bar hook pads down 1 Hole ? I also Plan to put front air bags on it as soon as they arrive.
All adjustments to air bags were made before hooking up the weight distribution bars
15 psi bags 600# bars
B 37 1/8 A 36 5/8” pass rear
B34 3/16 A34 1/16 Pass front
B34 1/2. A34 1/2 driver front
B37 5/16. A36 7/8 Driver rear
With three children and me and the wife working opposites to ensure constant child care it’s hard to get free time to make all the changes going back and forth. Would like to make the most of my time available with as much information as possible in hand prior to trying a bunch more things. I would like to have it figured out prior to getting ready to head out next time instead of a boat load of trial and error when I should be hitting the road instead.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Dec 02, 2025
