LarryJM
Mar 14, 2015Explorer II
Rhoadzie wrote:
Here are my specs and the specs of my trailer.
Cheverolet 1500 Silverado Ext. Cab HD Towing package
Gross Axle Wt Rating - 3950 lbs (3950.0 min/3950.0max)
Front Gross Axle Wt Rating - 3950 lbs (3950.0 min/3950.0max)
Rear Curb Weight - 3217 lbs (3217.0 min/3217.0max)
Front Curb Weight -2057 lbs (2057.0 min/2057.0max)
Gross Vehicle Weight Rating Cap - 7200, 7000 lbs (7000.0 min/7300.0max)
Maximum Trailering Capacity - 10400 lbs (10400.0 min/10400.0max)
2015 Grey Wolf 27rr
Delivery weight 5762
GVWR - 7965
Tongue Weight - 965
That trailer appears to be a bumper pull toy hauler and generally those have an excessively high dry hitch wt. so that when the cargo area is loaded the hitch wt. goes down. The general rules about hitch wts. except that 13% you want when road ready do not apply reliably. I think I would go with the 1200lb if you are looking at the Equal-i-zer and an investment in a Sherline tongue scale would be highly recommended so you know what your real hitch wt. is before you get on the road since it would vary depending on your cargo load.
Something you need to consider is what your receiver is rated at since I could see this hitch wt. at times pushing 1300 or even 1400lbs on the outside with more around 1100 to 1200 being more normal, but these are all pure guesses.
Larry
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
