Bob_Landry's avatar
Bob_Landry
WD Question For Ron
If you have a conventional tow trailer with a tongue weight of 1000 and with a properly adjusted WD, 300lbs is transferred back to the steering axle and the remaining 700lbs is transferred back to the trailer axles, how much weight have you added to the payload of the truck besides the weight of the hitch?
  • Ron was the first guy who came to mind, but any good answer is appreciated. I'm not arguing, I'm asking. I'm trying to understand how weight that is transferred from the hitch to the trailer axles has to be subtracted from the trucks payload. It seems like it just goes back to the trailer.
  • TomG2 wrote:
    ...What you asked is not reality. One would not want to transfer all thousand pounds off the rear axle, even if it were possible.
    Agreed.
  • BarneyS wrote:
    I think I am right in the following. If not, I'm sure Ron or somebody else will be along to correct me. :)
    Roughly speaking you have added around 700lbs to the payload.
    That 300lbs that was transferred back to the truck front axle is weight that was leveraged off of it by placing the tongue on the ball, not weight added from the tongue. The weight on the axles before drawing up the WD bars would be around 1300lbs - 1000 from the tongue and 300 from the front axle of the truck.
    Then about 300lbs of the 1000lbs is transferred back to the trailer axles leaving about 700lbs of the 1000lbs left on the truck to be subtracted from the trucks payload.
    Barney
    That is correct.
  • You may want to PM Ron, if his is the only answer you are looking for. What you asked is not reality. One would not want to transfer all thousand pounds off the rear axle, even if it were possible.
  • I think I am right in the following. If not, I'm sure Ron or somebody else will be along to correct me. :)
    Barney
  • If yo have a trailer with a a tongue weight of 1000 lb and you put it on your hitch then you added 1000 lb to your payload.
Looking for advice before your next adventure? Look no further.25,128 PostsLatest Activity: Apr 24, 2025
