SC_camper's avatar
SC_camper
WDH adjustments after hitting scales
We took delivery of our 2013 Dutchmen 261BHS Friday. We loaded it with almost everything we had in the old camper while at the dealer. The Dutchmen came with a Huskey 800-1000lb WDH. It must have been used with a 4x4 because it was 8 inches to low. We flipped the shank and adjusted it with a tape measure and the old "eyeballing it" method. We left from the dealers lot for our first weekend trip. On the way home I hit the scales.
With the current setup, the TT is 1 inch higher in the front than the back, The front axle of TV is the same height and the rear dropped 1 1/4 inches. Making the TV level front and rear. The weight bars are pointed slightly up towards the frame. Using the 6th link.
TV without TT, Steer axle 3500
Drive axle 3860
Total 7360
TV with TT and WDH, Steer axle 3520
Drive axle 4660
TT axle 6620
Total 14800
I think the numbers look good, but need to drop the ball height.
What do ya think?
How critical is it to have the WD bars level with the TT frame?
Is the tongue weight 800lbs?
