splashback's avatar
splashback
WDH for 2500 Truck necessary?
I am new here and have decided on a Ram as the upgrade from my GMC Envoy.
I currently tow a camper that weights about 5000lbs fully loaded. Hitch weight is about 450-500lbs.
I currently have a weight distributing hitch and assume due to rear end sag, the Ram 1500 would also require using one.
Do you think a Ram 2500 would need the WDH? I would use sway control, but getting rid of the WDH would be great.
Thanks in advance.
  • My Ford's hitch specifies it is rated for 600 lbs. tongue weight & 6,000 trailer weight without weight dist, 1,250 lbs. & 12,500 with.
  • I don't know about Dodge, but Chevrolet does not require a weight distributing hitch with their 2500/3500 models. I use my Andersen no sway hitch with my 2500HD for the extra sway control, only because I already owned one. I put very little tension on the chains.
  • I have one for my D-max and use it but it's not needed and my trailer is about 2,000 lbs heaver. The only reason I still use it is because I had one. I just snug the chains and there is 0 load and call it good.
    So no, I don't think you need one.
  • I went from a '97 K1500 using an Equilizer 4-Way, to my sig truck. The WDH didn't fit the Dodge because of the truck receiver height. I went for a run without WDH and determined that I was fine. Never spent the ~$100 for the longer/taller shank that would have allowed use of my WDH. I ended up giving it to my father in law since he was looking at purchasing the same one I had.
    We've done many trips with and without toys in the trailer, and it has pulled great.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 16, 2026
