deerhunt799's avatar
deerhunt799
WDH help
My tow vehicle is a 2014 F-150 Max Tow. TT is a 2011 Heartland North Trail 24rbs. Brochure (yeah, I know these can't be trusted) tongue weight is 352lbs (UVW - 4980lbs, GVWR - 6900lbs). The UVW tongue weight seems extremely light, even by manufacturers standards (not sure if it's the wider axles?).
So my question is, would the Eaz-Lift 600/10,000 WDH be sufficient? My initial thought is no based off the 10-15% tongue weight rule of thumb. Again, not sure if the wider axles of the trailer truly have a lower tongue weight.
  • Once you figure out what size is required, likely the Pro Series RB3 WDH (500, 750 or 1000# tongue weight) advertized on etrailer for $214 with free shipping, would work. The 750 model works well for our 2720 Trailmanor, Durango (TV) and our billfold.
    https://www.etrailer.com/Weight-Distribution/Pro-Series/PS49582.html
  • Sorry, disregard. The CL seller was giving me the weight carrying specs instead of weight distribution specs. They're actually 1000# bars. Thanks!
    Did you find the yellow sticker? It should be there somewhere, Maybe on the left front with the tire info. It will tell you the actual weight of the TT as it left the factory. Including empty propane tanks, and battery.
    Having said that. I believe you would be borderline with 600lb bars
  • Get a hitch that would support the trailers GVW with average tongue weight. That would be about 800 - 900 lbs tongue weight.
    Depending on actual loading, 800 lb bars could be undersized, so, move up to next weight rating at 1000 lbs.
  • Remember tongue weight on their specs do not include the battery, full propane tanks, weight distribution hitch weight. That's easily a total of 250lbs or so. Right there you would be at the max of the WD hitch. Load up, weight the tongue, then buy a hitch. That's what I had to do after buying a WDH too small for my TT.
Looking for advice before your next adventure? Look no further.25,195 PostsLatest Activity: May 02, 2026
