Tvov
Sep 30, 2014Explorer II
I don't use the spring bars on my WD hitch when towing to a couple local campgrounds, which are within less than 5 miles over local (slow) roads. When planning on highway travel, I hook everything up. You might be able to greatly reduce the spring tension on the bars. Basically, play with the adjustments on your hitch a bit.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 17, 2025
